General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
90 Truck Flasher Relay Hazards work no Blinkers
Old Sep 26, 2008 | 04:14 AM
dip1's Avatar
Is there only one relay for this truck? I have no blinker lights but my hazards lights work. I found one near the left of steering column when I turn on my hazards this clicks fine. If I turn on my blinkers the same relay buzzes sometimes but no lights blinking. I saw a green relay on the fuse block not sure what that was.
Old Sep 26, 2008 | 04:26 AM
jsn_stockard's Avatar
mine did that few years ago. I had to replace the entire switch
Old Sep 26, 2008 | 07:37 AM
eric-the-red's Avatar
There is only one flasher relay, if the hazard lights are working then the relay is fine. Do all the bulbs work. The turn signals and hazard lights have seperate fuses, check the one for the turn signals. And like jsn_stockard said it could be the switch.
Old Sep 26, 2008 | 10:01 AM
dip1's Avatar
Are you taking about the switch in the steering column? What is wierd I am getting continuity on all four wires! I can touch any of the 4 wires on the front of the truck and they all have continuity. Plus like I said when I turn on the blinker the relay makes a buzzing sound like its trying to click.
Thanks!
Old Sep 26, 2008 | 11:51 AM
Yes, the turn signal switch operates the flasher relay when the hazards are off. If the switch isn't making good contact then that could be the problem.
Old Oct 12, 2008 | 08:11 AM
Pickupon35s's Avatar
Mine does the exact same thing i cant figure it out
Old Oct 12, 2008 | 08:58 AM
schmooot's Avatar
I've had luck with other vehicles just taking apart the switch and cleaning the contacts....sometimes the gunk just builds up in there and starts to mess with things.
gillesdetrail
Nov 19, 2019 12:56 PM
gog1968
Jun 22, 2015 05:55 AM
Dennis140
Jun 17, 2015 10:37 AM
HBoss
24
Jul 1, 2002 11:37 PM
