General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
airbox conection
Old Sep 5, 2008 | 12:50 PM
OSJ's Avatar
OSJ
airbox conection
hi guys, i have a 90 runner with the 3.o. it is not starting now but if i unplug the cinection on the airbox(mass air flow sensor?) it will start right up but then die. if it is plugged in it will just crank over and over. need help, what can i do?
thanks
Jay
Old Sep 5, 2008 | 12:55 PM
4Crawler's Avatar
Likely the fuel pump contact in the AFM. Test it out:
- http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
And try the fuel pump test jumper to see if that makes it run:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old Sep 5, 2008 | 05:50 PM
OSJ's Avatar
OSJ
none of the pics show my engine and i'm not to familiar with wiring on trucks.
the starting problem stated a few days ago when once ina while it wouldn't start. but if i opened up the airbox and gave it a squirt of ether it fired up after a few cranks. then today nothing at all. and as i said, if i unplug the air sensor ont eh breather box it starts up and dies right away.
i just bought this runner and need to fix it asap.
any other help would be greatly apreciated.
Old Sep 5, 2008 | 05:54 PM
4Crawler's Avatar
The above two links I provided would apply, at least try the fuel pump test jumper (you have the diagnostics box and would jumper the FP and B terminals:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
The AFM should be similar, but a Factory Service Manual would have the details for your engine:
- http://www.4crawler.com/4x4/FSM.shtml
Old Sep 7, 2008 | 10:12 AM
OSJ's Avatar
OSJ
so before i tried the other things mentioned, i pulled the little black cover off the mafs adn had a torn foil strip. so i soddered it back on. what kind of silicone do i use to seal the lid again?
thanks
Old Sep 7, 2008 | 04:31 PM
OSJ's Avatar
OSJ
got it all back together and running as good as new. man, saudering those little floi strips is a pain in the ass.
toyotasaurus
Sep 24, 2015 03:30 PM
agrout
Sep 3, 2015 07:50 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Luke
24
May 27, 2003 02:19 PM
UKMyers
23
May 25, 2003 10:10 AM
