General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
3.4 swap, tach fix?
Old Oct 14, 2006 | 04:08 AM
Bajatoy's Avatar
3.4 swap, tach fix?
Okay, I have literally searched all night for some info on this and cant find anything. I bought an ors kit, and in the instructions it says you can solder in a resistor to fix the tach to read correctly and that the info can be found on here or pirated4x4.
Does any body have the info on how to do this? I have looked over both sites and cant find a thing!
Thanks for the help.
Brian
Old Oct 14, 2006 | 06:43 AM
breknraj's Avatar
Bajatoy, check these picks from Mt. Goat's thread https://www.yotatech.com/forums/f160/3-4-swap-started-82145/ for great write ups and pics.
These two may help:
http://rides.webshots.com/photo/2443...42310107egMiRf
http://rides.webshots.com/photo/2124...42310107gMlKlu
All that I have read has said to use a 1/4 Watt 10K Ohm resistor, but Fallman told me that he chose to use a 1/2 Watt 10K Ohm.
Good luck with yours -I'm doing mine today!
Old Oct 14, 2006 | 11:55 PM
Bajatoy's Avatar
thanks, that helped out a lot.
Let me know how your tach fix went.
Fairly easy?
Thanks again
Brian
Old Oct 15, 2006 | 12:42 AM
Bajatoy's Avatar
sounds stupid, but I am and electrical idiot and hate the idea of doing this off of pictures. Is there a thread that tells where to solder in the resistor? The thread explaining why was awsome, I enjoyed that. 4x4 wire said they where going to do a write up on it in there tech section but I cant find it.
Thanks
Brian
Old Oct 15, 2006 | 07:31 AM
breknraj's Avatar
Mine went great! I'll have to wait to test it when I get the truck running, again, though. The only part I was unsure of was opening the instrument cluster. I thought that the speedo and tach faces were part of the surround, but Mt. Goat's picture showed that it wasn't, so off the cover came.
I unscrewed the tach from the back, and carefully removed it. Watch out here, as the face of the guage will fingerprint very easily. I soldered my resistor across the connections shown in Mt. Goat's pic. The new resistor bridges the same connections as the original on the other side of the board (new one is lower value, thus least resistance) I suppose that you could remove that board and replace the original resistor, but that would expose the mechanism of the to potential damage in the process.
Despite my caution, I ended up smudging some skin oil from a knuckle on the face of my guage, and then went nuts trying to clean it! I tried some mild cleaners, but they all left streaks on the face. For lack of any other ideas, I finally wet my microfiber lens cloth with my tongue, and that finally cleaned the face back to its proper flat black!
It is now back together, and re-installed in the dash of my truck.
Old Oct 15, 2006 | 08:50 AM
mudbutt's Avatar
I used the pirate4x4.com FAQ for mine, i think it was on the third page.
I didn't know the wattage of my resistor, it is a 10k ohm
Old Oct 16, 2006 | 08:47 AM
mt_goat's Avatar
You don't want to remove the original resistor, that would change the overall resistance. Someone figured it out already what works so just go with it, mine works great now.
Old Oct 16, 2006 | 08:52 AM
mt_goat's Avatar
Yeah that's where I got my info too, here at the bottom of page 3 (it used to be on page 4):
http://www.pirate4x4.com/forum/showt...=459180&page=3
Old Oct 16, 2006 | 09:18 AM
mt_goat's Avatar
Thanks
Brian
It is best to use a small pointed tip soldering iron and thin solder, like .032 diameter 60/40 Rosin core (no bigger than .050 dia) With the delicate board and small trace lines you don't want a big honken soldering gun with 200 watts. You'll have to cut and bend the leads on the resistor short enough to fit in place. Only heat the points on the board enough to melt the solder that's there and with tweezers stick the resistor wire into the puddle, then after you have both ends in place add just a little more solder to secure it good, but don't go hog wild with the solder or heat.
Old Oct 17, 2006 | 06:42 AM
breknraj's Avatar
[QUOTE=mt_goat;1014868]You don't want to remove the original resistor, that would change the overall resistance. Someone figured it out already what works so just go with it, mine works great now.
I must have missed or forgotten reading that anywhere, but I just added the 10K to the back of mine, as is. I didn't want to open up the mechanism, and I figured that this had obviously worked for other folks, so why mess with success. Yours are the best pics I've seen of the mod, IMO, Mt. Goat, so I didn't even bother to take any of mine.
Old Oct 17, 2006 | 07:45 AM
Bajatoy's Avatar
cool, thanks for the help.
I will post up some pics when I start my swap too. Wont be for a couple of weeks though, still working 6 12 hours day for another couple of weeks! I dont recomend it.
Any way, 3.4 going into a 94 ext cab 4x4 that will now be 2 wheel drive!!!!!
T-100 tranny and the works.
Thanks again
Brian
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
94whiterunner
Jul 12, 2015 07:15 PM
