Power Locks are POSSESSED!!!
Help! If I unlock the passenger door on my 02 4Runner the locks automatically lock themselves right away. If I unlock with the key fob, same thing, with the button inside, same thing. It was funny this afternoon because it locked and unlocked by itself for about 20 seconds. Because I've narrowed it down to the front passenger door doing this, any ideas whether its electronic or something else? Thanks in advance!
try reprograming the key fob. Another trick might be to disconnect the battery for a few minutes. fob programing procedures below.
1. unlock all of the doors in the car, open the driver's side door, and make sure the key is not in the ignition
2. put the key into the ignition and then pull it out without turning it or anything
3. within 40 seconds, lock and then unlock the doors five times using the power lock button on the driver's side door.
4. close the door and then open it again
5. within 40 seconds lock and then unlock the doors five times again using the power lock button.
6. Put the key into the ignition and turn it to the on position (not acc and not far enough to actually start the engine) and then back to the off position, then back to on and back to off.
7. Pull the key out of the ignition
8. If you are successful, after about 5 seconds, the doors should power lock and then unlock on their own. If that doesn't happen then try again from step 1.
9. within 40 seconds, hold down the lock and unlock button simultaneously on the remote for a second. Then release and hold down the unlock button for 3 seconds. The power locks should cycle again once on their own. If they don't cycle exactly once, repeat this step from the beginning with the remote again.
10. Repeat step 9 for every remote you want to program. You have to do this with any remotes that were previously programmed because this process essentially resets what remotes the car will respond to.
11. Close the driver's side door to signify that you are done programming the remotes
Jun 1, 2021 01:51 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
