General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Total Rewire?
Old Jan 20, 2010 | 02:29 PM
CitrusTheDragon's Avatar
Lightbulb Total Rewire?
Has anyone done a full rewire? I have a ton of wiring issues in my truck and am thinking I will just do a rewire. I would like to add a tech and found that in the 80's they had one. Just need to find a year and if the wiring I have will work. I also wanna add power windows, door locks, an alarm systems, and get the rear window tied in. If anyone has done this please let me know I would like some advice. Oh and anyone know if there is an easy way to do it
Old Jan 20, 2010 | 02:34 PM
BigBluePile's Avatar
well, if you have the money get a Painless wiring kit. It'll come with everything you'll need!
Old Jan 20, 2010 | 02:50 PM
ibeamtaco's Avatar
its a huge job i just installed aftermarket dash with gauges all new switches a Lawrence gps and a race radio it was ruff
Old Jan 20, 2010 | 04:20 PM
With everything I plan on adding to my truck I need at least a couple more fuse spots
Old Jan 20, 2010 | 04:51 PM
ibeamtaco's Avatar
http://www.amazon.com/Ancor-607122-M.../dp/B000NI3CM2 this is what i used
hardest part 4 me was wiring turn signals and lights to toggle switch kinda cool tho
Old Feb 6, 2010 | 10:33 AM
Do u have a pic of ur dash kit???
Old Feb 15, 2010 | 02:23 PM
Pumpkinyota's Avatar
I am in process of doing this now, I will post a thread soon. So far so good, I bought a painless 20 ckt waterproof offroad harness. I have had to make some minor adjustments, but so far it is working out. It is not, however, a quick project. Also, what kind of truck do you have? My '79 is completely de-smogged now. When I bought it, I had to swap out a non-functional 20r for a new 22r motor before I could smog and register it... had to re-wire the ECM from scratch... and I REALLY don't recommend that unless you havequite a bit of experience.
Old Mar 7, 2010 | 09:31 PM
milehigheric's Avatar
I rewired my stock system for 2 reasons....I wasnt using the stock ECM (running aftermarket controller) or any of the that goes with it. Second wanted to upgrade the loom in places it was lacking...headlights,starting,charging mianly + a few AUX devices.
It is honeslty not that dificult, although it is time consuming and I wouldnt advise it if you are just trying to fix issues with the stock loom. Most of your time should be in planning...the stock areas of my loom was built around the toyota stock loom anyway to keep things simple.
live4soccer7
May 11, 2016 06:52 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Chicken12
Oct 14, 2015 03:54 PM
Brodetski
Sep 30, 2015 11:50 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
