General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Instrument cluster fried?
Old Mar 8, 2010 | 10:21 AM
airkewld4life's Avatar
I took my cluster out today to replace some bulbs with LED ones, plugged everything in to test the bulbs and the circuit board started to smoke. Anyone know why? It started at the oil pressure and water temp light and worked its way to the bulb right in the center.
Old Mar 8, 2010 | 10:30 AM
DeathCougar's Avatar
I did this EXACT same thing over the weekend in my MR2.
My mistake was touching the aluminum bulb ring to the cluster while I had the lights on.
The only way I can fix mine is to find a used circuit board from someone. I would guess that you will have to do the same.
Old Mar 8, 2010 | 10:32 AM
Think I could have touched something on the steering column that would have caused this?
I already ordered a new/used cluster
Old Mar 8, 2010 | 10:40 AM
If I plug it back in will most the lights still work?
TheBFA
Feb 15, 2020 06:55 AM
Jdgarrison
Oct 1, 2015 05:22 PM
87SR5justin
Sep 15, 2015 06:48 PM
imhousing
Sep 10, 2015 02:04 PM
Rawwdz
Sep 6, 2015 09:03 PM
