ABS disable mod for 05+ Tacomas w/o VSC & Trac Control
I've been trying to figure out how to do the ABS disable switch mod to my 2wd tacoma. My truck doesn't have VSC or Trac and all the threads I have seen show how to disable it on trucks with VSC and Trac. I have been studying these wire diagrams a little bit.
http://www.ncttora.com/fsm/05+/data/.../h/em01d23.pdf
http://www.ncttora.com/fsm/05+/data/.../h/em01d12.pdf
And to my understanding the brake light switch has to be closed in order for the ABS ECU to activate the ABS pump to prevent locking up the wheels? Is that correct? If it is then it would make sense just to interrupt the signal from the brake switch to the ABS ECU. Only problem is which wire is the signal from the switch to ECU to interrupt? The stop light diagram shows 2 wires going from the brake light switch to the ECU. Please help if you have any input. I really want to be able to disable the ABS when I go off-road with the flip of a switch. TIA
Also, I've been told that pulling the fuse or running a switch in line with the fuse is not the answer. Problems with blowing fuses and worst of all loosing power braking assist.
I'm an idiot, I was looking the brake light switch all wrong
. In my truck (w/o VSC or TRAC) there is only one wire going to the ABS ECU from the brake switch. I didn't realize the asterisks in the top corner (*1: w/ VSC *2: w/o VSC). So my truck's schematic doesn't include the Stop LP CTRL Relay circuit. So I just need to confirm that interrupting the signal from the brake light switch to the ABS ECU with a switch will disable the ABS from kicking in when braking off-road and only the ABS (not power assist). Am I correct? I know there are quite a few us out there that would love to have this mod. Please any input is greatly appreciated. TIA
Im not sure on the one you are working with just went through my 1990 with rear abs that was not working properly and could not get them working than figured that there is a fuse for the abs pull the fuse for the abs and not the brake light I also took the step of pulling the abs brain out that is above the glove box and now im back to 4 wheel brakes in my contol instead of two wheel brakes like I had hope this helps
priest16
15
Aug 6, 2015 07:43 AM
vanion2
Jul 29, 2015 06:17 PM
