General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
wig wag help
Old Jul 8, 2010 | 02:25 PM
zanzabar0's Avatar
wig wag help
im looking to get a set of wig wags for my 94 3.0 pickup to respond to fire calls with and am not sure on how my wiring is set up in my truck. the light description on galls.com says that the galls wig wag flasher cannot be used on vehicles with ground side switched headlights. so i am confused on what that means and if it is possible for those to work. if anyone has a pair of wig wags installed i could use some tips please. thanks
Old Jul 8, 2010 | 02:40 PM
Fink's Avatar
I used a Whelen SlimLighter in my Tacoma - bright as hell and they mounted inside either the windshield or back glass.
I'd go that route personally - I'll sell you mine if you want it.
Fink
Old Jul 8, 2010 | 02:44 PM
zanzabar0's Avatar
i actually have a slimmiser and i love it haha. i have it right in front of my rear view where it fits perfectly. thanks for the offer
Old Jul 8, 2010 | 02:46 PM
Fink's Avatar
That's a good bar too, I had that one before this one.
I was amazed how much brighter this one was.
Good luck on the wigwags - I never had any luck with mine.
I ended up just getting a cheap strobe set from www.sirennet.com
Fink
Old Jul 8, 2010 | 03:24 PM
xxxtreme22r's Avatar
you might find info on working this out as far as the negative ground goes by wiring it with a relay like we do for the headlight harness upgrade. You end up switching from switched ground to switch positive through the relay harness.
Old Jul 11, 2010 | 02:17 PM
zanzabar0's Avatar
so the pickup is a switched ground setup?
Old Jul 11, 2010 | 03:11 PM
wsntme's Avatar
Several years ago I had a wig-wag setup in my tacoma. Due to the switched ground setup I had to order a flasher from a guy who was making them @ the time. Unfortunately I've just read on the website (Thundercat Electronnix that he's out of business. I figure there has to be a similar company though that could get you what you're after. I found the guy and his company through ebay if memory serves my right.
pfdaxe
Sep 21, 2013 07:55 AM
andrix
Apr 22, 2010 10:03 AM
