General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Another rear window question!!!
Old Sep 4, 2010 | 04:27 PM
gary_the_4runner's Avatar
in my 94 4runner the rear window rolls up and down with the key and rolls up with the switch in the center console, BUT DOES NOT ROLL DOWN USING THE SWITCH. where should i start???
i searched... got nothing
thanks in advance!
Old Sep 4, 2010 | 04:46 PM
myyota's Avatar
Check out 4crawlers web site, he has a section on how to trouble shoot and repair your rear window.
Old Sep 5, 2010 | 05:43 PM
i checked out the website, GREAT STUFF!
still... i dont want to tear up the interior to identify the wire/relay giving me the issue. i was hoping someone had a similar issue that was a simple fix. maybe a new switch (not making contact)? or repair the relay in the rear corner? i know it works, it just needs to roll down from the switch up front.
maybe im dreaming, and there is no simple fix...
Old Sep 5, 2010 | 06:20 PM
myyota's Avatar
In the rear window relay box there are four relays, one makes the window go down, one makes it go up, one is for the rear wiper and one is for the rear defrost if you have it, so if its not rolling down it could be a bad or dirty switch, a broken wire, or a bad relay in the relay box.
Old Sep 5, 2010 | 06:22 PM
yami_racer74's Avatar
My '95 had the same problem. Just pop the botton out the center console and clean up the connectors with a pencil eraser. Did the trick for me and only took about 10 mins.
Old Sep 5, 2010 | 06:29 PM
i will try cleaning first and then move on to the relays...
myyota, do you know which relay is which on the board???
Old Sep 5, 2010 | 06:48 PM
i tried cleaning the blue connector the switch is attached to, no luck.
i will try a different switch before i dig out the relay box.
i looked up part numbers of the relays on 4crawlers site and none of which were found on either website does anyone know of a different p/n???????
edit: found omron relay http://www.onlinecomponents.com/buy/...S/G5LE-1-DC12/
Old Sep 5, 2010 | 07:57 PM
myyota's Avatar
When we talk about cleaning the switch, were not refering to the blue plug, you need to take the switch a part and clean the contacts inside. I also rebuilt the relay box on my 86 4Runner, i used a 12 amp relay, and i think the stock relays are rated at 8 amps.
Old Sep 6, 2010 | 09:45 PM
thanks myyota, is there a trick in getting to the in-erds of the switch?? i will get into it a little more tomorrow morning and hopefully take pictures and do a little bit of a tech write-up. any help is appreciated!!
another quick question, what the best way to get the dome light lense off, the bulb burnt out. i wanna check the fuse first obviously, i think its in the no.2 relay box under the hood, right?
Old Sep 6, 2010 | 10:47 PM
myyota's Avatar
To get the switch a part CAREFULLY pry the bottom off, be careful not to loose any of the internal parts, clean it and put it back together.
The dome light lens just pops off, and the fuse for the done light should be behind the driver side kick panel.
Old Sep 7, 2010 | 08:41 AM
took the switch apart today, broke a side of the casing (whoops, but it still holds it and you cant tell.) and got it back together. AND IT WORKS, i'm glad i did this and didnt attempt to fiddle with the relay, thanks to all that helped me!
took the switch out
another view....
took the little bulb out.
took switch, spring, lever and contacts out of the case, eye glass screwdriver cracked the casing.
used the pencil eraser to brush of any residue that was on there, im assuming from the grease/lube where the spring met the lever. put it all back together, plugged it in and watched from the rear view as my window rolled up and down!
Jun 1, 2021 01:51 PM
rushw
Jul 18, 2015 01:46 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
coryc85
Jul 6, 2015 04:07 AM
