General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
can I fix this: instrument cluster
Old Feb 2, 2011 | 06:24 PM
crawlerjunkie's Avatar
Was going to do the v6 gauge swap in the 87 and found this on the P.C.B.
1.Can it be fixed?
2.Is it just for the lights.
3.should I try to find another gauge panel?
Old Feb 2, 2011 | 07:07 PM
rworegon's Avatar
Can what be fixed?
Old Feb 2, 2011 | 07:18 PM
the broken strip in the center of the pic.
justin_4runner's Avatar
yeah, just solider a piece or wire to each side of the split, just make sure u get the solider on the wire first and then touch it to the board. that way u wont burn the board too much.
Old Feb 2, 2011 | 07:20 PM
oh yeah did u find the problem that caused it? cause if u do fix it and u didn't fix the problem it might cause more problems,
Old Feb 2, 2011 | 07:26 PM
Thats what i was thinking, the panel came out of a non running truck so i dont know
Old Feb 2, 2011 | 07:32 PM
rworegon's Avatar
It almost looks like someone tried a prior repair and it burned out again.
A good resource:
http://www.circuitrework.com/guides/guides.shtml
Old Feb 2, 2011 | 07:50 PM
scuba's Avatar
Soldering flex circuit is a PITA.
Just be careful or you'll mess it up more than it already is.
Old Feb 2, 2011 | 09:53 PM
dropzone's Avatar
Fossilized
you need to check the other side of that circuit (flip the board over but it probably sealed) and see if there is a resistor, cap or something popped..
.I would just find another instrument cluster
gary4runner
Sep 24, 2015 12:53 AM
mund1011
Aug 16, 2015 07:10 AM
teknovls
Aug 9, 2015 12:37 AM
rushw
Jul 18, 2015 01:46 PM
