General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Voltage at Tps?
Old May 7, 2011 | 02:42 PM
Pach's Avatar
Voltage at Tps?
I have been having a major issue. I rebuilt the heads on 924runner 3.0. The whole install went well. until it came time to start the thing. It fired right up first try but dies immediately after. I have chased this problem all over the place!! Ive chevked all the vacuum lines and im positive they are correct. I know I have fuel and spark because I can give it some throttle and keep it running but as soon as I let out it dies. I have replaced the TPS, VAF, and ignitor!! Which was not cheap!
Today a buddy unplugged the TPS and tried to start the truck. It started and he was able to keep it from dieing with some pedal. There was basically no change in performance at all. I then checked the signal wires from the TPS plu to the ECM and the checked out good. Then I checked the TPS for voltage and I had nothing.... Shouldnt I have some sort of reference voltage present at the TPS plug with the ignition in the on postion???
Please Help
Old May 7, 2011 | 04:39 PM
justin_4runner's Avatar
here is the fsm for the electrical for the ecu, in here will be the info ur looking for.
http://www.ncttora.com/fsm/1990-1995...emci/eng3r.pdf
Old May 7, 2011 | 05:15 PM
Pach's Avatar
Ive looked at this. but it is unclear what voltage (if any) should be present at the sensor whith the key on. It seems I have no TPS Signal.
Old May 7, 2011 | 11:12 PM
this page shows what voltages for the tps.
http://www.ncttora.com/fsm/1990-1995...yste/engin.pdf
Old May 8, 2011 | 10:02 AM
Pach's Avatar
I see said the blind man! Thanks
Longbed 90
Oct 19, 2015 11:05 AM
Chicken12
Oct 14, 2015 03:54 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
JPV
Sep 28, 2015 03:15 PM
larrys93pickup
Sep 17, 2015 07:05 PM
