General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
85 22re w/t fuel deliviery problem
Old Nov 28, 2010 | 05:55 PM
88THMPR's Avatar
Hey Folks,
The 85 22RE 4Rrunner that I picked up was missing a few items when I bought it a short while ago.
Missing and now replaced items were:
Transmission
Ignighter/Coil assembly
Alternator
Battery
Female lead for the O2 sensor.
With all installed the motor does crank, has strong spark but no fuel.
I did spray starting fluid into the throttle body and it fired right up.
I pulled the fuel rubber hose from the fuel hard line on the passenger side of engine comparment and it was DRY.
There is 2-3 gallons in the tank. I don't hear the pump when I turn the key - should I?
Fuses are all good.
Aside from pulling the fuel pump, what else should I try to remedy this problem?
Much thanks in advance for any and all advise!
Norm
Old Nov 28, 2010 | 06:25 PM
Philbert's Avatar
Have you searched here for some ideas?
http://www.4crawler.com/4x4/CheapTricks/index.shtml
Old Nov 28, 2010 | 10:45 PM
88THMPR's Avatar
hey thanks for the link! GOOD stuff!!! Yep found what I was looking for.
Old Dec 5, 2010 | 04:57 PM
crash707's Avatar
that site is awesome! i just found out what i needed about my idle not being stable after i dropped in an 84? 22r into my 92 22re truck. i swaped all of my efi stuff to this block and it wasnt doing good lol. however my fuel economy sucked before. (hint #1) then the idle was up and down. im gonna check it. hope it works, and i hope the tps is not expensive haha
Charecter1
Nov 6, 2023 10:08 AM
jbv808
Aug 6, 2021 04:47 PM
steve miller
Oct 10, 2015 01:40 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
karbin
Jul 5, 2015 11:37 PM
