General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Wiring help
Old Jan 17, 2011 | 05:23 PM
hunter 4321's Avatar
Wiring help
So I have two questions, first here is my situation, pulled 3VZE out of 94 toyota pickup, next installed 97 passat 1.9TDI engine, now I am working on the wiring. I need to constant power once the key has been turned to power the glow plug control and open up the fuel shutoff solenoid. I have put the sensors for water temp and oil pressure from the v-6 on the vw engine, just need to get the wires hooked up.
Question one, does anyone have a pin-out diagram for a 3vze that has 26-16-22 pin. I have looked everywhere and can not locate one.
Question two, my new alternator is 120amps, the stock one on the Toyota was 80amps. What if anything am I going to need to upgrade or change make this operate properly, or can I just hook it strait to the battery with a 120amp fuse in line.
Thanks for your time with this matter.
Old Jan 26, 2011 | 10:06 AM
Hadmatt54's Avatar
There is a link to a 90-95 4 Runner manual over in the 86-95 truck section, if the wiring colors match yours it might help or someone on this forum may have the exact diagram that you need. Other than that it's a great investment to have the manuals (repair and electrical) for your year truck try ebay, that's where I've purchased mine.
80a. to 120a. alternator upgrade... I would upgrade the wiring for the alternator circuit.
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Daneums
Jul 28, 2015 11:57 AM
TDonkey
Jul 26, 2015 10:14 AM
