General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Front signals don't work, hazard light do.
Old Jan 23, 2011 | 09:22 AM
likus101's Avatar
hey there, i've got a '97 4Runner, my emergency flashers work fine, all the bulbs are good, yet my turn signals don't work at all.
I've replaced the flasher relay, and that didn't do a thing. I know the turn signal switch on the column is not the problem. Also, i do have factory daytime running lights. I'm stumped. Any advice would be much appreciated.
Old Jan 23, 2011 | 02:19 PM
matt1992's Avatar
Is it both right and left not working? and is it in the front and/or the rear? If you need a wiring diagram, I could get one to you...
Old Jan 23, 2011 | 02:27 PM
Elton's Avatar
check all the fuses first
Old Jan 30, 2011 | 10:02 PM
likus101's Avatar
both front and back, right and left don't work. I checked all the fuses. I don't know what to do.
Old Jan 31, 2011 | 07:29 PM
matt1992's Avatar
Top half of diagram
bottom half of diagram
Mitchell wouldn't let me copy and paste or save as so i had to rig it up and this is the best diagram i can get for you. Sorry if it is hard to read
Old Jan 31, 2011 | 11:14 PM
likus101's Avatar
That's great. I'll check them out and see if i can't find anything. Thanks alot guy, much appreciated.
Old Feb 2, 2011 | 06:52 PM
Techsus's Avatar
Golly-- my front/rear turn signals went out today, too! Holy mackeral. I had the sense to check emergency flashers, they're working OK. Where are the fuses for the turn signals? I have a 1991 Toyota Xtra Cab Deluxe pick-up, 2WD, 5-speed.
Thank you!
Old Feb 2, 2011 | 10:55 PM
likus101's Avatar
the flasher relay on my rig was up behind the dash. But i swapped it out and that didn't fix it.
Old Feb 3, 2011 | 09:10 PM
Techsus's Avatar
HAPPY-ENDING Story.
Well, it's 23 Degrees F. here but I HAD to go check my flasher relay. Phoned Stealership earlier today, "Would you like to schedule with Service to have those fixed?" Sure! Not. Talked to my Service Guy, he said "You need a new flasher." Famous last words.
Flashers are $56.xx new + tax. He said well if BOTH aren't working, it's NOT the fuse. So I was reading on line about what happens when the flasher (relay) fails-- turn signals don't work. (Earlier I made sure to turn on each turn signal, get out of my truck, walk around-- to reassure myself that the turn signals were NOT working inside OR outside. They weren't working anywhere.
So, late tonight, went back out there, after reading about where to find the flasher relay, I was confident I could locate it (on drivers side, near fuse panel near door hinges) BEFORE freezing to death. At least I'd die happy. Didn't see relays right off, but I did see fuse-panel door. Removed that. A diagram on inside of door had everything outlined nicely... the LAST thing I saw was "Turn Signal." Ah-hah! Ran back into house for my Leatherman. Gingerly (didn't want to crush it) removed Turn Signal fuse. In the dim light, it (at first) looked "OK" but to reassure myself, pulled a 10-Amp fuse from the "Gauges" slot & plugged that into "Turn Signal" slot. Got my keys, turned key to "Alt" (without cranking engine), then clicked on my right turn signal.
Guess what?
Blink-blink-blink. It worked.
Now all I have to do is find a 10A fuse for the Gauges slot... maybe I'll get lucky and find some spare fuses in the other fuse box.... maybe there's one in the engine-- if anyone knows if there are spare fuses in the truck somewhere, let me know?
Happy Days!
Old Aug 25, 2012 | 07:02 PM
22R4X4's Avatar
Ever find out what it was? I have the same problem.
Old Aug 26, 2012 | 06:17 AM
MudHippy's Avatar
Speechless...
Old Aug 26, 2012 | 12:48 PM
Techsus's Avatar
It was simply the fuse. Just installed a new fuse & it worked.
Old Aug 26, 2012 | 12:51 PM
MudHippy's Avatar
Shame on you! You shouldn't enable bad behavior.
Now how's he going to learn how this is supposed to work?
gillesdetrail
Nov 19, 2019 12:56 PM
Yota.Jay
Mar 6, 2016 11:02 PM
gog1968
Jun 22, 2015 05:55 AM
