General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Crap. How do i fix this?
Old Dec 10, 2011 | 11:09 AM
FullOutPwr's Avatar
Well, was chasing down why I dont have tail lights/ running lights and dash lights and found it. I apparently broke a relay off the fuse box on the kick panel.
Old Dec 10, 2011 | 11:26 AM
FullOutPwr's Avatar
Well, I was able to get it to fit on and then i can hear the relay click when I turn the lights on. However, I'm not getting any power at the connector to the dash dimmer still.
Ideas? Is it possible for the relay to still be bad?
Old Dec 10, 2011 | 11:40 AM
FullOutPwr's Avatar
Update- power at relay, no power at tail fuse even after relay is plugged back in. Bad relay not completing the circuit?
Old Dec 10, 2011 | 12:36 PM
wyoming9's Avatar
Wink
Do you understand how relays work??
How did you manage to break it off?
Did you replace with the proper one and do you have it installed correct??
Did you test it??
Old Dec 10, 2011 | 03:20 PM
FullOutPwr's Avatar
More/less yes. I have no problems admitting I'm unsure how to test this relay. I searched online a little bit but somewhat confused. I pulled up the wiring schematic and am on the right track.
Pole 1 shows as input from the headlight switch. Pole 2 is an input from an underhood relay. when inputs from the 2 complete inside the relay, closes the electromagnet and flows to pole 3 and to the tail light fuse. As i'm not seeing any voltage at the tail light fuse no matter what, Its a problem with the relay or the 2 inputs although I hear the relay click.
I had to pull the pedals out to get them fixed when i experienced the clutch pedal failure at the bracket. Apparently me or my help caught the pedal assembly on the relay.
Edit- I'm actually seeing constant 12.5 volts on one of the poles that connect to the relay. I see nothing on the headlight switch pole when i flip on the headlights. Possible bad headlight switch? Although the headlights turn on and work just fine
Colington
Mar 8, 2020 09:51 AM
Yota.Jay
28
Oct 22, 2015 01:08 PM
Jason Webber
Sep 2, 2015 03:30 AM
ManzDaKlown24
Aug 22, 2015 10:25 PM
jjrbus
Aug 10, 2015 01:09 PM
