General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Ground ???
Old Mar 16, 2012 | 05:08 PM
RazrRebel's Avatar
Ground ???
I'm guessing I have a ground. When I hit the brakes the left turn signal goes solid. If not on the brake the park lights work fine, also the turn signals. I switched all the bulbs out and no change. I know I'm going to have a hard time with this. Was just wondering if anybody knows where to start, or have had the same problem.
Old Mar 16, 2012 | 05:14 PM
Team420's Avatar
start with a multi meter! You most likely have a bad wire(or 2) somewhere, Its not hard to find/fix, but does take some time, and patience....
Old Mar 17, 2012 | 03:46 AM
RazrRebel's Avatar
Any certain place I should start? I figure hold the brake down and start working my way back with the park light first. I was wondering if any body had any ideas on where to start or maybe a problem area that had this as a common problem.
Old Mar 17, 2012 | 12:53 PM
4Crawler's Avatar
has it always done this or did it just start? If a recent problem, was anything modified prior to the problem, i.e. new radio/amp/CD player/CB radio installed, or a trailer wiring connected added, or bulbs changed, etc.?
Old Mar 17, 2012 | 02:19 PM
wyoming9's Avatar
Red face
Sounds like it could be a corroded socket on the left brake light tail light socket.
Try cleaning that good with electrical cleaner and a fitting brush.
Also it would be nice to know what year??
As the older tail lights grounded to the outside of the socket.
Old Sep 4, 2012 | 05:23 PM
henrypaz's Avatar
Missing Ground?
I think you have two "hot" leads : signal and tail/brake lites feeding to one bulb with a common ground, or to two bulb sockets grounding through one lead. If the ground is not good, when you apply brakes for instance, the two "hot" signals cancel each other out? I found that cleaning the ground to the socket did the trick.
Hope this helps
Alexdosdall
Dec 10, 2017 05:48 PM
live4soccer7
May 11, 2016 06:52 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
charlie_fong
Sep 27, 2015 10:06 PM
Project90
Sep 24, 2015 11:40 PM
