General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
'94 Rear Window Defroster Switch
Old Feb 1, 2012 | 08:04 PM
Yota1DA's Avatar
In the process of wiring up some fog lights on my light bar. Pulled a typical stock rectangular rear window defroster switch with back side plug out of a 1994 4Runner. Back side plug has 5 wires - blue w/thin white stripe, white w/thin green stripe, black w/brown stripe, black w/yellow strip, and green.
Wanted a switch that would fit the stock switch bay. In order to wire the switch as an on/off for fog lights I only need 2 of the wires but which 2? Looked for a wiring diagram on the internet but no luck.
Any help would be appreciated.
Old Feb 2, 2012 | 07:19 AM
AreOhhEnn's Avatar
Without having a wiring diagram, the easiest way to find two wires to use is to grab a multi-meter and start checked which two wires have continuity when the switch is on and lose continuity when the switch is off.
My only concern (since I deal with wiring up ALOT of stuff as an installer) is if the switch is beefy enough to handle the current directly for your fog lights. I personally would use a relay with the switch to handle the electrical load that fog lights tend to draw.
Old Oct 26, 2015 | 08:10 PM
e6rock's Avatar
I know this thread is old, but did you ever get your switch to work with your fog lights Yota1DA? I just picked up a factory switch out of a 4runner as well and am looking to do the same mod.
Jun 1, 2021 01:51 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
icentropy
Jul 14, 2015 10:23 AM
Johntom240
7
Jul 13, 2015 12:18 AM
coryc85
Jul 6, 2015 04:07 AM
