General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Brake lights not working
Old Nov 7, 2011 | 03:59 PM
93dlxyota's Avatar
my brake lights are not working, i have checked every fuse on the truck and thier all fine, i have changed all the bulbs too. all lights work except brake lights. the brake switch is good.they work one day then the next day they dont. any help would be greatly appreciated.
Old Jan 18, 2012 | 05:00 PM
kingofnada's Avatar
any luck on finding the problem? I'm having the same issue, i can turn on the lights and everything works but apply pressure to the brakes nothing, changed the fuses, lights, switch still nothing, everything looks good, but not working.
Old Jan 22, 2012 | 12:22 PM
93NMyota's Avatar
the fuse that powers this is a 15A labeled "STOP". if this has power at both ends of the fuse check at the bulb for dirty connections or sockets, also i have seen intermittent problems with the brake switch. does yours have cruise?
Old Jan 22, 2012 | 12:49 PM
kingofnada's Avatar
yeah it's got CC, i ended up replacing all the fuses and cleaned the connectors, also changed the switch, and now everything works great...i saw some corrosion on the fuses i'm guessing that was the issue.
MudnBullets
Oct 28, 2018 07:00 PM
Aleeex_u
Jun 5, 2016 06:52 PM
miceal383
Jun 29, 2015 12:27 AM
gog1968
Jun 22, 2015 05:55 AM
ItsAtoyotaLIFE
Jun 21, 2015 11:45 AM
