General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
86 high beam indicator bulb number??
Old Feb 25, 2012 | 06:18 AM
mldave's Avatar
On my 86 Toyota truck STD cab the light is out on the high beam indicator.What's the bulb number and the removal procedure?
Old Feb 25, 2012 | 06:45 AM
Bassmastry101's Avatar
Very simple to replace. I think their are two screws above the cluster, two below it, and one on the left side hiding behind the door. Unplug everything and set it aside, unscrew your gauge cluster. Before you remove it reach your hand behind it and unhook the speedo cable. Press on the clip and gently pull the cluster at the same time and it will come out. Unhook all your wires and figure out which bulb it is, it will be the one behind the spot that illuminates.
Old Feb 25, 2012 | 06:51 AM
Philbert made a nice write up on it.
https://www.yotatech.com/forums/f116...10-mod-218638/
bulb should be #194 if not #74
Old Feb 25, 2012 | 09:32 AM
mldave's Avatar
Thanks man,my instrument cluster is different on the truck...but should be the same changeout.
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
rushw
Jul 18, 2015 01:46 PM
shisha1999
Jul 13, 2015 11:09 PM
