General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
fog light switch blows fuses
Old Feb 13, 2012 | 02:16 PM
bill_collector's Avatar
I started wiring up 2-55 watt lights yesterday. I wired it up using a 40 amp relay and a 20 amp capable illuminated switch. I wanted to tap the cig lighter for the switch power, but everytime I test them they will come on but when I turn them off it blows a fuse. I checked the wiring to the relay and had the ground and switch wire crossed. I fixed that thinking that was my problem. I then tapped the cig lighter fuse and the wire started smoking. This is my first wiring job and its very frustrating but I want to learn. Thanks for any help.
Old Feb 13, 2012 | 04:08 PM
Update:
I ran a hot wire straight from + battery terminal with a 30 amp in line fuse. I had it connected to the switch and when I touched it to the + terminal it blowed the 30 amp fuse. I double checked AGAIN that the wires were hooked up correctly to the relay and checked all other wiring. It was correct. I am now lost as a duck and at the mercy of yotatech. lol
Old Feb 13, 2012 | 04:14 PM
Sensei's Avatar
Have you pulled the lights apart and checked the wiring inside. Could be grounding internally... Try hooking up one light at a time straight to the battery.
Old Feb 13, 2012 | 06:10 PM
Before I started I held the red wire from light to pos post and black to neg post they worked fine. They would come on until the switch was tuned off and the fuse blew.
Old Feb 13, 2012 | 06:41 PM
justin_4runner's Avatar
unplug the lights and put a new fuse in and see if it blows when u turn them on, if it does then i would check that the switch is not wired wrong and where u are sending power to ground, if it doesnt blow then hook up one light and retest, if it blows then it that light if not then go to the other light and hook it back up and see if it blows then,
u might have to replace the switch due to hooking up the wires wrong it could of fried something inside the switch.
Old Feb 15, 2012 | 04:41 PM
Hey Justin it was one of 2 things. I replaced the switch and the relay. They work great now. Not sure what it was that had em messed up to start with. I do have another question though. I bought all the relays the parts store had which was 4. They are all 4 different brands. Why is each relay supposed to be wired up differently? I was under the impression that 30 would always be coming from the + terminal. 2 of the relays has the lights coming to 30. I just wired them to the relay the way the instructions said on the back.
Old Feb 15, 2012 | 06:39 PM
some relays have 2 power out puts and some are power to one side when off and power to the other side when switched on.
ashersullivan88yota
Jan 18, 2022 05:37 PM
HookahRoo
Jul 20, 2015 07:06 PM
rushw
Jul 18, 2015 01:46 PM
Johntom240
7
Jul 13, 2015 12:18 AM
madxman21
Jul 9, 2015 10:26 AM
