General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Cruise Control Help Please!!!
Old Sep 19, 2012 | 06:40 PM
ACZR's Avatar
Hello, I am having problems with the cruise control in my 1991 Pick up (3.0) I believe it is aftermarket, it is mounted on the dash, by the dimmer switch (my '91 4 runner had it on the stearing wheel). The small control unit will light up when I switch it to on, but nothing happens as far as holding speed.Am I doing something wrong in the setting process?? Obviously there is some power to it? Thank you for your advice.
Old Sep 19, 2012 | 06:47 PM
ThatGuy1295's Avatar
Aftermarket criuse? Not sure about it?
If its a manual trans make sure your clutch is all the way out before engaging cruise. Lot of times the pedal is out of adjustment and doesnt come up all the way be itself. Theres a clutch sensor for the clutch being all the way out so the cruise can work, and a pedal down sensor for the starter safety circuit. 2 sensors, good thing to check.
Other then that some pics of the switch and setup would help us identify for you.
Old Sep 19, 2012 | 06:48 PM
I know when I first got my taco the cruise didnt work. I had to lift the pedel up alittle with my foot then it worked fine.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
kcaudill
Oct 10, 2015 02:39 PM
Shagool22
Sep 28, 2015 07:53 PM
toyotasaurus
Sep 24, 2015 03:30 PM
