General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Custom Fabricated . . . Paper Clip
Old Nov 29, 2011 | 01:07 PM
norcalairman's Avatar
I was having trouble starting my 4Runner after I'd been driving around and after some googling I decided to test the Circuit Opening Relay. Sure enough, it worked like a charm. It was a cheap fix too, only costing a paper clip, which I expertly crafted into a jumper that would fit under the plastic cap marked "DIAGNOSTIC".
If there is no danger, I'm perfectly happy just leaving the paper clip there. Any concerns?
Old Nov 30, 2011 | 11:08 AM
camo31_10.50's Avatar
i dont believe there is...but this is a bandaid fix and the problem should be fixed for real
Old Nov 30, 2011 | 11:15 AM
93toyrunner2's Avatar
Eventually, something in the electrical circuit will "let the smoke out"! Ask me how I know. I used my jumper in an emergency coming down the smokey mountains, and I made it to the bottom. You may want to look at it before the smoke gremlin comes to visit when you least expect it, 200 miles from home for example.
Old Nov 30, 2011 | 11:20 AM
Yeah, this is definitely temporary. I'm just trying to keep things running until I can get it fixed without getting raped by a mechanic.
Old Nov 30, 2011 | 11:21 AM
xxxtreme22r's Avatar
You might want to understand what that COR when activated does and the side effects of it being activated 100% of the time. That's a diagnostic port not a bypass/bandaid port
Old Dec 1, 2011 | 06:24 AM
That's a good point. The bottom line is I need to get it fixed correctly ASAP.
live4soccer7
May 11, 2016 06:52 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Brodetski
Sep 30, 2015 11:50 PM
toyotasaurus
Sep 24, 2015 03:30 PM
