HELP! No power to anything!
So I changed my battery the other day and while I was at it I threw in a new t-stat. started up fine. temp started rising on the gauge so i figured my heating problem was in my radiator. turned car off to let cool down. turned back on to move truck. got the buzz from the key switch then all of a sudden it just stopped, along with every other electronic in the truck. I've checked all my fuses and grounds and no luck. I don't even get any power to my dome lights just sitting. Anyone have any ideas? I'm supposed to be selling my truck this weekend and this has thrown a real wrench in the gears. If anyone has any knowledge on relays and what not that would be great. I've check through my Haynes manual with no luck....
Thanks
-Dylan
Thanks
-Dylan
yes im having the same problem right now i just tuck the whole fuse block out withe the wire harnes thet gose to the head lights and alt and some outher conection on the drivers side its going to take awhile now undo all the tape and loom youl find your problem mine ihad two wires brock off at the factroy crimps at the splices witch go to uther things so i would start thire it seams to be a problem on all older toys good luck one thing at a time youl geter
delmert
Sep 30, 2015 04:34 PM
