General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Acell coil issues
Old Mar 20, 2012 | 11:09 AM
3YLSYKR's Avatar
Acell coil issues
I hooked up an acell coil and can't get it to start. It stumbled a lil but not full start. It would vary depending on how far I pushed the plug wire onto the coil. I have a set of some good red wires from ebay. The wires work great with Toyota round coil but not with the acell 8140c. I don't think I would need the 8140hv. The acell coil won't even work with stock wires. I'm at a loss, not sure what's going on or what to do.
Anyone else have issues like this with upgraded coil?
Old Mar 20, 2012 | 01:18 PM
Outsane's Avatar
my 22re wouldn't stay running till I had the ign wire connected to the correct side of the ignition coil...
try swapping the black wire to the other side...
Old Mar 20, 2012 | 01:49 PM
3YLSYKR's Avatar
It runs both ways with wires well did. Can't get AFM right now, won't stay running or adjust its self with AFM changes and filter off. Something makes howling noise from back of motor. I'm getting fed up.
Old Mar 20, 2012 | 02:27 PM
Outsane's Avatar
just go back to the old coil then
Old Mar 20, 2012 | 02:30 PM
3YLSYKR's Avatar
I am and won't work now. Should have left it alone.
Old Mar 20, 2012 | 04:02 PM
Outsane's Avatar
so the only thing you messed with is the coil?
Old Mar 22, 2012 | 09:36 AM
3YLSYKR's Avatar
Yeah that's it. I installed stock coil back in and trying to tune to run right with AFM but now it wont. I don't know where the stock setting on AFM is, where I should be, I'm all sorts of messed up now. I wish I had a wideband to help me tell where to tune it to. I ordered a new TPS thinking that's been an on going issue with it why it stumbles and what not. I hope that's the case but then have to try and tune with the AFM again and hope it works.
Old Mar 22, 2012 | 09:54 AM
Outsane's Avatar
ok so at least the coil is not an issue, you just have the AFM issues..
good luck
Old Mar 22, 2012 | 11:02 AM
3YLSYKR's Avatar
That and the TPS I think. It's just one thing after another. The coil is an issue hence it wont work with the acell coil that others use ok and mine wont. I don't get it.
Old Mar 22, 2012 | 11:47 AM
BMcEL's Avatar
Check for codes. This should ALWAYS be the first step when troubleshooting.
And test parts before replacing them. Don't just throw parts at it...fix it.
Old Mar 22, 2012 | 11:52 AM
3YLSYKR's Avatar
I'll have the codes checked, but no lights on dash.
I tested the TPS a while back like I read to and it tested failed so that's why I bought a new one. I tested it while adjusting the timing of the motor.
It has aftermarket cam but the timing was high seemed like to I put down to about stockish around 7-8. I think it was at 11, can't recall. Seems to run good still.
The way I tested the TPS was by jumping the two sensors in the drivers fender area to see if it drops rpm and it didn't so that's how I read it fails. I had to jump the tps to adjust timing if I remember right. I hope I get it running good again, I'm gonna go out and mess with it today to see if it changed. I heard you can pull a 15A fuse under the dash somewhere to reset stuff.
Old Mar 22, 2012 | 01:10 PM
BMcEL's Avatar
Not all codes illuminate the check engine light. You can pull codes yourself:
http://www.4crawler.com/4x4/CheapTri....shtml#Reading
Might just need to be adjusted. Test it using the following method:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Mar 23, 2012 | 01:21 PM
3YLSYKR's Avatar
Thanks for the info, I'll test and see what it says and go from there.
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
Numberonedad6
Jul 30, 2015 07:10 PM
konah
Jul 30, 2015 02:08 PM
ddg71
Jul 24, 2015 01:24 PM
