General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
no headlights or tail lights
Old May 6, 2012 | 02:36 PM
thomas.baker's Avatar
i recently bought a 1979 lwb 4x4 with the 20r and a 4 speed manuel, the problem is the lights wont come on, any of them, head lights, taillights, break lights, dash lights, none of them work and i have no idea what the problem is
Old May 6, 2012 | 03:02 PM
rworegon's Avatar
Does it start? Have you checked:fuses, ground, wiring for breaks, burnt out bulbs?
Old May 6, 2012 | 03:09 PM
starts fine, changed fuses, checked grounds and wires, bulbs are good
Old May 6, 2012 | 03:31 PM
rworegon's Avatar
Headlight relay? Combination switch? You will need to break out the volt meter and see what you have going on.
Use the FSM link in my sig line and find a manual close to your rig and look in the Body Electrical section.
This may help:
http://www.ncttora.com/fsm/1985/1985FSM_OCR.pdf
Old May 7, 2012 | 07:57 AM
okay, finally found a broken wire and now the head lights work but break lights and tail lights still dont work
Old May 7, 2012 | 08:00 AM
waskillywabbit's Avatar
Probably the same issue. Broken wire or bad ground.
:wabbit2:
Sep 4, 2015 09:27 AM
mreagen
Aug 18, 2015 06:37 AM
skebe22RTE
Jul 31, 2015 02:03 PM
PopsDad1
Jul 30, 2015 02:21 PM
Johntom240
7
Jul 13, 2015 12:18 AM
