General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Innovate motorsports mtx-l air fuel gauge
Old Oct 16, 2012 | 08:04 PM
RylerTust's Avatar
I just got a 4runner and this was already installed. What's the purpose? Looked em up and these things are really expensive. What's the point? I've been too I can use this to help with fuel economy? Anyone know what's up with these? Thanks!
Old Oct 16, 2012 | 08:15 PM
j-man's Avatar
ur truck probably had a supercharger on it, or maybe turbo if someone was trying to monitor the A/F ratios....thats the only reason to put one there, unless the previous owner thought it was really cool to add useless gauges.
Old Oct 16, 2012 | 09:41 PM
RylerTust's Avatar
I don't think it did. Just a 1990 4runner with a 22re and a 5speeed. If it did I wish it was still
Old Oct 16, 2012 | 11:26 PM
warpigg's Avatar
if its a wideband a/f ratio gauge then its like a $200 gauge and there very nice to have even if it doesnt have boost running through it. if its a narrow band gauge then its worth like $20-$40, i really want one for my celica becaust of all the intake mods it has but cant afford it
Old Oct 17, 2012 | 06:17 AM
RylerTust's Avatar
It's wide band. I don't know why but it reads strange (to me) under normal throttle and idle it reads right around 14.7, but when I'm cruising and let off the throttle without engaging the clutch it reads 22.4(gauge maxed out) hmmmm. I've been told these are good to learn to drive more economically.
Old Oct 17, 2012 | 12:17 PM
shelshelly90's Avatar
14.7 is perfect for idel, thats what you want for a AFR at idel. when your at WOT it is going to read less than 14.7 which means it is richer. and when you let off the gas and slowing down under compression it is going to read above 14.7 which means little or no fuel is going to the motor, thats perfectly normal
Old Nov 11, 2012 | 07:35 PM
vital22re's Avatar
totally a bro
warpigg knock it off. Only warning I give. I cleaned the thread up.
If runs lean when you let off because of fuel cut by the ecu. Its running just fine and normal. 14.7 is stoich= normal air to fuel ratio. The ecu tries to keep it 14.7 under most driving conditions till you hit WOT. Then it hits 12 to keep it safe.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
gary4runner
Sep 24, 2015 12:53 AM
calderp
Jul 27, 2015 09:58 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
smiley52
Jul 11, 2015 05:16 AM
