General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
wiring my inverter
Old Sep 15, 2009 | 07:08 PM
skibum707's Avatar
wiring my inverter
so i just got a 800 watt inverter and unfortunatly all it comes with r little two foot power chords with alligator clips on the end to conect to the battery. the wire is 8 ga and my question is can i run about 10 or so feet of 8 ga wire to the battery and just ground in the cab where i want the inverter? or would 10 ft be too long of a stretch for the 8 ga and where do u buy 8 ga wire?
Old Sep 16, 2009 | 06:11 PM
aviator's Avatar
Here's a link for you https://www.yotatech.com/forums/f115...verter-191576/
8ga may be a bit too small for you it depends on how much draw you are going to put on that 800W inverter and how far away from the batt. you plan to mount it. At a min. I would use 6ga and 4ga would be even better the wiring will run cooler with less resistance and the inverter will work better also.
Remember unless it a sealed marine rated unit inverters really don't like to get wet so pick a dry location.
You can get the wire from almost any HD or Lowes or an Electrical Wholesaler... Wiring with finer strands will be more flexible and easier to route through the body/frame then wiring with heavier strands. Protect the wire where ever you go through a hole in the body/frame with a grommet or piece of bicycle inner tube sleeved and zip tied around it to prevent chafing.
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Daneums
Jul 28, 2015 11:57 AM
TDonkey
Jul 26, 2015 10:14 AM
