General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Question on wiring up back up lights
Old Nov 14, 2009 | 06:32 PM
GenXr's Avatar
I'm installing a pair of tractor style work lights on my rear bumper and want to wire them so they come on automatically when I go in reverse but also want to be able to turn them on on demand.
I'll be using a relay and tapping the reverse light to hook up to #86 on the relay to trigger the relay to turn on. I also want to put an independent switch hooked up there to turn them when ever I need light.
My question is, how to wire up the switch so I don't back feed the reverse lights and damage the factory circuit?
Old Nov 14, 2009 | 08:09 PM
ID96_4Runner's Avatar
Simply use two relays with battery power tied in parallel through the two relays. So your two relay triggers (back up lamp, and toggle switch) will be independent circuits, but the battery to work light circuit will be a single circuit that can go through either relay.
Old Nov 14, 2009 | 08:16 PM
BigBluePile's Avatar
What about a diode?
Old Nov 14, 2009 | 08:55 PM
Elton's Avatar
how about a 3way switch
Old Nov 16, 2009 | 04:59 PM
GenXr's Avatar
I considered to relays but wasn't sure how to wire them together. A friend also mentioned a diode, although I don't have any experience with them I think I understand how the protect the factory circuit.
The schematic on the 3-way switch looks pretty simple. Based on what you've shown me I'm going to go that route. I'll post some pics once it's done.
Thanks for the replies!
Old Dec 1, 2009 | 08:48 PM
scyotapu's Avatar
yes, a rectifier diode would be really simply also. it will only allow power to travel one way. just make sure you get the right amp size. dont get one to small or you'll backfeed and it will heat up to much. make sure you dont put the diode anywhere where it will catch things on fire, cause they can heat up alot when exposed to electricity for a while.
GreenLion
Jun 7, 2021 10:49 AM
Bru
Jun 23, 2015 06:58 PM
Taz22R
Jun 21, 2015 04:44 PM
Beavah
9
Nov 12, 2013 07:31 PM
