General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
changed out driver signal lights
Old Oct 20, 2009 | 06:09 PM
jesseunvoas's Avatar
i just bought this truck two weeks ago and i had to change out the rear signal light so i figured i might as well do all the bulbs since i had LED's in my 82 pickup and everything seemed fine until the front signal light. what would happen is when i turn the right way to signal it does the flash faster like in my other truck as if i had a burnt out bulb but on the driver side as soon as i changed the bulb out the flasher would stay on always and not flash. so has anyone ever come across this problem. I can't send my truck in to be safetied until this issue is resolved so any help is appreciated.
Old Oct 24, 2009 | 09:21 AM
i guess what my problem was, was that when i put in LED bulbs there wasn't enough resistance and then it would just stay on all the time i guess i will have to find out what resistor i need to put in line to even out the current
Old Oct 24, 2009 | 09:37 AM
4Crawler's Avatar
6 ohm, 50 watt resistor, one per side is what you need. I have a pair I wired up to a 4-pin trailer wiring socket that I had installed on my '85. No longer need it but if you have a trailer wiring plug, this would plug right in.
Old Oct 24, 2009 | 04:49 PM
thanks i will pick some up at the electronics supplier when i have a chance
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
madxman21
Jul 9, 2015 10:26 AM
coryc85
Jul 6, 2015 04:07 AM
