General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
92 Truck Lights
Old Dec 15, 2009 | 03:45 PM
1160049's Avatar
92 Truck Lights
Hi Guys I have a 92 Toyota Truck ex cab 4 Cylinder 4x4 standard. When I bought the truck a year ago I removed the remote start (aftermarket) that was half disconnected. At the point of disconnection the head lights worked (running/low & high beams)
After a careful removal and patch up of the wiring I don't have High beams, but when I pull the switch in both the lows and highs come on.
Any ideas before I go out in the dark ?
Jon
Old Dec 15, 2009 | 03:46 PM
Elton's Avatar
combo switch might be bad
Old Dec 16, 2009 | 12:00 PM
1160049's Avatar
Thanks Elton For the suggestion, How would i go about testing the switch ?
Any onther suggestions ?
Old Dec 18, 2009 | 06:24 PM
scyotapu's Avatar
can you test the voltage comming from the highs? see if the ground is breaking when you release the switch. put the multimeter in the "hot" connector on the headlight, and ground your multimeter to a known ground, not on the harness. are you still getting current?
gillesdetrail
Nov 19, 2019 12:56 PM
Aleeex_u
Jun 5, 2016 06:52 PM
rbravo1
Jun 29, 2015 01:34 PM
Bru
Jun 23, 2015 06:58 PM
