General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
screeching turn singnal
Old Jul 24, 2009 | 09:59 AM
toyminater88's Avatar
i have an 88 pickup and when i use the right signal it just screeches what could my problem be?
Old Jul 24, 2009 | 10:00 AM
Elton's Avatar
flasher relay going bad ?
Old Jul 24, 2009 | 10:09 AM
OrRunner's Avatar
sounds like the relay, had the same problem after a sandblasting guy didnt tape off my inside of my 4runner. bought a new turn assembly for 35.00 from a junk yard and was good to go. mine was not specificly the realy but the connection was not being made in the signal arm it self which set the relay a screechin.
Old Jul 24, 2009 | 11:01 AM
DeathCougar's Avatar
The screeching has nothing to do with the relay. Its toyotas built in safety feature that tells you "Hey dummy, none of your bulbs are blinking" or "Hey dummy, you are not getting proper signal from the switch"
So, you either A. have burned out bulbs or B. a problem in your turn signal switch. Check the obvious first.
Old Jul 24, 2009 | 12:50 PM
OrRunner's Avatar
I didn't know it would make noise if your bulb was burnt, good to know, with mine personally it was the connections in the actual housing where the lever sits, due to sand getting in there. Thanks DC if i hear that horrid noise agian i will def. check the bulbs
Old Jul 24, 2009 | 10:17 PM
i figured it out! the wires going to my brake/signal/reverse lights got caught under a bed mount and got worn down untill they broke a few new connectors and im good to go
okamikai
Apr 30, 2018 10:19 PM
Shoua
13
May 22, 2016 05:19 AM
Dakotaneu
Aug 15, 2015 07:24 AM
JHalcyonM
Aug 4, 2015 01:19 PM
Hamonacracker
Jul 17, 2015 08:33 AM
