General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
1995 4 runner water temp sensor A cicuit
Old Jun 22, 2009 | 07:42 PM
Sunny461's Avatar
Smile 1995 4 runner water temp sensor A cicuit
On my 1995 4Runner - V6, I've been tracing /repairing a string of AC problems. Now down to one -- the system will operate properly ONLY if # 3 terminal (pink) is grounded. This wire goes to the water temperature switch - it had a broken wire but the switch is also bad. If I ground the wire the system works/cycles properly - My question is can this sensor be bypassed - it looks like a PITA to get to or can someone give me the correct Toyota part number for this sensor, you wouldn't believe the hassle I ha dtring to get the cutoff relay - which all the dealers were telling me was in the engine compartment and not behind the glove box where I removed mine from.
Any help would be appreciated - THANKS
Old Jun 23, 2009 | 05:59 AM
4Crawler's Avatar
Probably be OK as long as you keep an eye on the engine temps with the A/C running. If the engine temps start to creep up out of it's normal range with A/C on, you may need to shut off the A/C to let the engine cool down if needed. A/C amplifier has always been behind the glove box on the Toyota trucks, at least on the 1st and 2nd gens, a factory Service Manual would show the part location.
Old Jun 23, 2009 | 06:26 AM
Sunny461's Avatar
Thank you., Yes the amp and the cutoff relay were exactly where the manual told me they were but you wouldn't believe how difficult it was to convince 2 toyota parts dept of that! Anyhow - thanks for you help. Have a great day
vasinvictor
Jan 20, 2016 12:39 PM
OffroadRalph
Jul 2, 2015 07:28 PM
Bru
Jun 23, 2015 06:58 PM
Mutinebullfrog
Jun 18, 2015 01:36 PM
95Runner
Jun 9, 2002 09:08 AM
