General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
I need help with a 30A Relay
Old Nov 21, 2009 | 01:41 PM
B4Runner's Avatar
Exclamation I need help with a 30A Relay
I just completed the rear-window-switch-in-cargo-area mod. I also want to add a switch to turn on the reverse lights for lighting in the dark while camping. I have a 30amp 12v relay.
30
85/86
87
I (splice) connected the constant hot tailgate key wire to the 30 and the reverse light to the 87. (At this point, I only know that my reverse wire is the properly connected one.) I then took a spare battery and some wire. I touched the + to 85 and the - to 86 and then vice versa. Either way, I could here and feel the relay working. Very strongly by the way. My main problem, though, it that the reverse lights WONT come on. That's why I'm now asking for help. Thank you in advanced!
Old Nov 21, 2009 | 01:56 PM
mic's Avatar
mic
do you have it grounded properly
Old Nov 21, 2009 | 02:07 PM
B4Runner's Avatar
i grounded it straight to another battery. and the relay was clicking on and off as i touched the 85 to + and 86 to -
Old Nov 21, 2009 | 02:29 PM
mic's Avatar
mic
ok it works with another battery. but that isnt a ground the system works with. clean of a spot and start from there.
Old Nov 21, 2009 | 03:34 PM
B4Runner's Avatar
but the circuit closes in the relay, its obvious. wont it do the same thing if its grounded sumwhere to the truck. and this switch is goin on the rear panel in the cargo area new where the speaker holes are. where would b my best closest ground point? i tried the jack holder mount bolt, but that didnt work either. what would be your suggestion?
Old Nov 22, 2009 | 07:27 AM
B4Runner's Avatar
Should I make my connections differenly? The relay closes when I connect the 86 and 85 to another car battery.
Old Nov 22, 2009 | 11:45 AM
Elton's Avatar
wire it up like so the aux fuse box wire is just a fused 12v hot
http://www.4runners.org/image/hella5...auxfusebox.jpg
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
Rcbc92
Sep 26, 2015 03:00 PM
runnermedic
13
Sep 21, 2015 05:20 PM
