General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
85 4Runner A/C Question
Old Aug 10, 2009 | 03:17 PM
sam24462's Avatar
The A/C on my 85 4Runner only works every now and then. Sometimes I get in and it will blow cold air and other times nothing. Sometimes it will stop working if I hit a hard bump.
Is there some sort of impact sensor that would shut it off or do I have a loose wire somewhere? I didn't see any switch on the wiring diagrams in the FSM but maybe it is built into another component. Any other ideas?
Thanks
Old Aug 21, 2009 | 09:16 PM
myyota's Avatar
I would say you either have a loose conection some were or a bad relay. the relay for the a/c (if i remember right) is under the dash behind the radio.
Old Aug 21, 2009 | 09:27 PM
v6854runner's Avatar
who needs ac on an 85 runner?
Old Aug 22, 2009 | 07:57 AM
4Crawler's Avatar
Thanks
Look in the AC section of the FSM, way in the back of the book. There are wiring pinouts for connectors and such. I would check all the ground connections. I once had a bad ground for my cruise control and if I hit a bit with it engaged, it would drop out.
MO transplant
Apr 23, 2023 11:58 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
87turboPA
Jul 12, 2015 07:49 AM
bryan34w
Jul 6, 2015 05:53 PM
