General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
starter relay location
Old Nov 5, 2009 | 06:33 PM
91yota91's Avatar
I have a 91 22re 4 runner with starter issues. starter works when u apply voltage to it. so its an issue with the relay or ignition switch it self. any ideas on where the starter relay is at? its not in the fuse block or on the passenger side fender or drivers side. and i didnt see it behind the glove box. any help. thanks
Old Nov 5, 2009 | 06:45 PM
Agent Orange's Avatar
Not all Toyotas have this starter relay if I remember correctly. So it's either starter solenoid or the ignition. From 4Crawler, here's a place to do some investigating.
Hopes this helps.
http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
Be sure to scroll up for some more tests to do.
Old Nov 8, 2009 | 04:44 PM
bugs1961's Avatar
In '89 only the manual transmissions had a starter relay and it is located on the passenger side fender sidewall, back towards the charcoal canister. This is a link to the '95 and it shows it located in the engine compartment fuse/relay box behind the battery. file:///C:/Documents%20and%20Settings/Rich/Desktop/Toyota.4Runner.1990.1995/Toyota.4Runner.1990.1995/FSM/toyewpdf/vfewdsou/1995/954runne/relayloc/relayloc.pdf
I have attached a photo from my paper '89 FSM also.
Should be in one of those locations. On the '95s both manual and automatic trans had the relay. Don't know when they changed it, though, because I just have the '89 and '95 manuals.
If you have an automatic then you may have a problem with the neutral safety switch on the transmission. Try jiggling the shift lever and also try starting it in neutral as opposed to park.
Old Nov 9, 2009 | 07:49 AM
djrez4's Avatar
I believe your starter relay is located under the kick-panel in the driver's footwell. There's a thread on here somewhere that has pictures.
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ghostmoney
Aug 6, 2015 08:40 AM
clok
Aug 1, 2015 09:42 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
colinmil
Jul 6, 2015 04:03 PM
