General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Electrical gremlin(brake/blinker/reverse)
Old Oct 18, 2009 | 05:34 PM
Albert.G's Avatar
well hello there ladies and gents. I have a pretty big problem on my 89 3.0 toyota 4x4 pickup. It happend every so often, and now its stuck on All the time. The problem is when I hit the brakes, the interior dash lights come on as well as the front and rear blinkers. anyone have any clue as to what this is? thanks alott!!1
Old Oct 19, 2009 | 08:04 AM
Albert.G's Avatar
nobody ever had this problem?
Old Oct 19, 2009 | 09:04 AM
4Crawler's Avatar
Could be a bad ground, check the cab ground, typically located in the driver's side kick panel, screw into the sheet metal with a "bunch 'o wires" hooked to it. Might also be a bad brake light bulb, perhaps someone put in a single filament bulb in place of a dual filament bulb. Remove the brake light bulbs and see if the problem mains or not.
Old Oct 30, 2009 | 08:07 AM
SafariRNR's Avatar
I agree on checking the bulb, sometimes when a dual filament burns out only one filament burns out (i.e. brakes but not tails or vise versa.) When this happens the burnt out filament can fall on to the good filament and cause all kinds of interesting lighting (i.e. hitting the brakes and all lights in the car brighten up like a brake light) Confused the hell out of me the first time I saw it.
Old Oct 30, 2009 | 10:56 AM
Ron Helmuth's Avatar
your brake light circuit and parking circuits are joined.
Do you have a towing lights connection 4 or 7 pin at the back end? That is where my problem started like this....
Old Feb 21, 2010 | 06:16 PM
frombozeman's Avatar
Help me too
I have the same thing happening. What did you find it to be?
Longbed 90
Oct 19, 2015 11:05 AM
Obmi
Oct 4, 2015 11:30 AM
voiddweller
Sep 28, 2015 11:21 PM
Project90
Sep 24, 2015 11:40 PM
xzen73x
Sep 14, 2015 03:00 AM
