charge light an brake light stay on
I have an 86' 22r ! Was going 4 a drive this morning and my charge &brake light stayed on , so took it 2 sears they said bad alt. Also went 2 a good shop they also said bad alt.
Took the alt. Back 2 napa where it was bought and checked it an said it was good?
I'm lost now............ Need some goood imput
I just washed my engine and under carridge and my charge light and brake light are now on. It sounds like it is just my alt. or did i do something to the brake system too? By the way it is a 94 4runner 3.0.
Sam prob
i have an 84 22r with a very similar prob only if i rev the enginge one good time the light will go off. if i keep the rpms below 2K it will stay on. i need help. it seems like evrything id fine i just dont want to get stranded somewhere for something i could have fixed.
All of you have either bad alternators, or the charge is not reaching the battery correctly.
Replacing the brushes is one POSSIBLE solution, and a cheaper option that the whole assy. But you will be out the money if the brushes doesn't fix it. As for those of you who power wash electronics.....stop doing that. Electricity and Water don't mix, despite what Monopoly might tell you!
The brake light is also a Caution light. So, with the charge and brake light its just letting you know there is an issues with the charging system. 90% of the time its the alternator.
O how i miss
Another vote on trying new brushes first. Also another vote on STOP PRESSURE WASHING YOUR ELECTRONICS. And maybe if you can get your head in there see if the connections are corroded or funked up. clean your battery terminals. Regular truck ain't broke but i wanna do something stuff.
ashersullivan88yota
Jan 18, 2022 05:37 PM
Odin
Jul 15, 2015 09:28 PM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
