General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
charge light an brake light stay on
Old Sep 22, 2009 | 07:34 PM
MT. GOATA's Avatar
I have an 86' 22r ! Was going 4 a drive this morning and my charge &brake light stayed on , so took it 2 sears they said bad alt. Also went 2 a good shop they also said bad alt.
Took the alt. Back 2 napa where it was bought and checked it an said it was good?
I'm lost now............ Need some goood imput
Old Sep 22, 2009 | 07:37 PM
waskillywabbit's Avatar
Of course NAPA said it was good, they don't want to give you ANOTHER one. Charge light and brake light means bad alternator.
Old Sep 23, 2009 | 10:33 AM
brian.243's Avatar
I just washed my engine and under carridge and my charge light and brake light are now on. It sounds like it is just my alt. or did i do something to the brake system too? By the way it is a 94 4runner 3.0.
Old Sep 23, 2009 | 12:12 PM
olharleyman's Avatar
change the brushes before you replace it ,4crawler.com has the brushes and a wright up on how to do it $9.00 vs.$100+ bucks makes a big difference.
Old Sep 23, 2009 | 06:35 PM
TW45ACP's Avatar
Sam prob
i have an 84 22r with a very similar prob only if i rev the enginge one good time the light will go off. if i keep the rpms below 2K it will stay on. i need help. it seems like evrything id fine i just dont want to get stranded somewhere for something i could have fixed.
Old Sep 23, 2009 | 06:51 PM
Go get your alternator tested for free at your local auto parts place.
DeathCougar's Avatar
All of you have either bad alternators, or the charge is not reaching the battery correctly.
Replacing the brushes is one POSSIBLE solution, and a cheaper option that the whole assy. But you will be out the money if the brushes doesn't fix it. As for those of you who power wash electronics.....stop doing that. Electricity and Water don't mix, despite what Monopoly might tell you!
Old Sep 23, 2009 | 07:15 PM
ScottyC's Avatar
The brake light is also a Caution light. So, with the charge and brake light its just letting you know there is an issues with the charging system. 90% of the time its the alternator.
Old Sep 23, 2009 | 07:23 PM
24Runna's Avatar
A bit off topic but does replacing the brushes increase power at all?
Old Sep 23, 2009 | 07:36 PM
JeEVeS's Avatar
O how i miss
Another vote on trying new brushes first. Also another vote on STOP PRESSURE WASHING YOUR ELECTRONICS. And maybe if you can get your head in there see if the connections are corroded or funked up. clean your battery terminals. Regular truck ain't broke but i wanna do something stuff.
Old Nov 19, 2009 | 12:04 PM
MT. GOATA's Avatar
thanks for all the tips. Alt. is fine , ended up tracking down all the wires and 2 were toast.replced all wires and solved problem . again thanks
Old Dec 2, 2009 | 03:51 AM
xxxtreme22r's Avatar
which wires were bad, I have the same problem.
ashersullivan88yota
Jan 18, 2022 05:37 PM
fountain
Dec 31, 2015 06:08 AM
Odin
Jul 15, 2015 09:28 PM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
