General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Power Window not going up
Old Jun 26, 2009 | 12:21 PM
SteveMars's Avatar
'93 4Runner.
Front Passenger window went down and won't go up.
Tried switches in both driver & passenger side doors - no sound/nothin'.
Can someone please provide troubleshooting steps to take?
Is there a way to manually roll it up?
Thanks.
Old Jun 26, 2009 | 12:54 PM
DeathCougar's Avatar
No way to manually roll it up, IF the motor is bad. If the motor is good, you can take apart your door panel and run power directly to the motor via a battery.
Old Jun 26, 2009 | 01:23 PM
kodiak90's Avatar
Did you check the fuses? That's where I'd look. Start with the least expensive stuff first and work your way through the system.
Old Jun 26, 2009 | 01:47 PM
SteveMars's Avatar
fuses should b good - all other windows werk.
will pull door panel apart and go from there - thanx.
Jun 1, 2021 01:51 PM
westonian18
May 1, 2020 06:38 AM
okamikai
Apr 30, 2018 10:19 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
Johntom240
7
Jul 13, 2015 12:18 AM
