General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
94 4runner lights won't shut off
Old Feb 22, 2015 | 08:33 AM
Gunrunner1's Avatar
PULLING MY HAIR OUT!!!! 94 4runner headlights won't shut off. I purchased a set of led headlights off ebay, installed them, but only had high beams, fought with those for a couple days, no luck sent them back, care installed stock headlights, and everything worked. ordered a different style from another vendor , installed them, and they kept blowing the fuses. Reinstalled the stock headlights, and now the lights will not shut off. Replaced the fuses, relay, and headlight switch. With the ignition and light switch off, the lights are on and the relay is buzzing.. Any help would be appreciated.
Old Feb 22, 2015 | 09:02 AM
wyoming9's Avatar
Red face
As the headlights ground via the headlight switch it is possible the pair that kept blowing the fuse.
Did some damage that is allowing them to ground hence they remain on.
Melted the wires or the sockets??
Did you ever figure out why the led bulbs were shorting out??
Old Feb 22, 2015 | 09:04 AM
Gunrunner1's Avatar
I did not , so, you're thinking I should check the sockets
Old Feb 22, 2015 | 09:21 AM
wyoming9's Avatar
Red face
I would look at every thing some place between the head light socket and the switch.
Your looking at the Red/green stripe wire being shorted to ground.
If you pull the fuses in the under hood fuse block the lights should go out.
Charecter1
Nov 6, 2023 10:08 AM
Jun 1, 2021 01:51 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
colinmil
Jul 6, 2015 04:03 PM
