General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
94 pickup taillights
Old Apr 11, 2015 | 08:26 AM
jamiesprague's Avatar
Just installed aftermarket taillights and now brake lights appear to be always on. No shift in brightness of bulb when I apply brakes. Brake switch under dash isn't sticking, used same bulbs from stock, and wiring to lights seems to be okay.
Any suggestions?
Old Apr 11, 2015 | 11:28 AM
wyoming9's Avatar
Red face
What kind of tail lights??
Where these brand new out of the box??
Someplace you have 12VDC going to your new lights.
Have you checked that your brake light switch is not electrically closed even though it looks to be in the off position??
Break out the Meter!!!
Old Apr 12, 2015 | 04:53 PM
They are spec-d taillights from carid.com. Yes, they were brand new out of the box and already wired.
Old Apr 13, 2015 | 12:19 AM
DavidLovesToyotas's Avatar
Your using single filament bulbs for your brake lights, look at the bulbs and make sure they are double filament.
Old Apr 13, 2015 | 05:06 AM
Bulbs are double filament and both are always on. Constant overheating is roasting bulbs glass.
Old Apr 13, 2015 | 11:43 PM
wyoming9's Avatar
Red face
Some how they are wired up wrong .
Or the brake light switch is always closed
With the light switch off brake light switch in the open position turn signals and flashers off there should be no battery voltage at your lights.
Your not trying to wire in a light that also includes your turn signals as they are always a separate circuit
Old Apr 14, 2015 | 11:08 AM
Do you still have the previous set of brake light assemblies? Id plug those guys back in, if they work fine, your aftermarket ones could just be faulty.
jasonty
41
Dec 23, 2018 01:00 PM
lledwod
Aug 30, 2016 01:03 PM
Sep 4, 2015 09:27 AM
toyota32
Jul 6, 2015 05:42 PM
