General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Solenoid resistor ???
Old May 23, 2014 | 12:37 AM
wyoming9's Avatar
Red face Solenoid resistor ???
I have to wonder who came up with calling the resistor for the injectors(solenoid resistor) or maybe it was Haynes in there manual that started it. It must be Haynes
In a few of my EWD`S it is just labeled a resistor In my 86 FSM EFI section it is called the injector resistor a much better term.
This always is frustrating to me as there is no solenoid in the injector system so how many may have spent hours trying to find the solenoid .
I never really knew where that name had come from till seeing it just now in a thread. Prompted me to do a little looking into it.
How many might Think it is related to the starter solenoid in some way
Old May 23, 2014 | 02:50 AM
Terrys87's Avatar
I have wondered that myself. Injector resistor would be more correct. I have seen a few other terms out there that have made me wonder as well.
Old May 24, 2014 | 10:24 AM
Hadmatt54's Avatar
It serves the same purpose as the resistor that the old Dodges had in the ignition circuit...lower the current. Dodge called it a "ballast resistor".
Old May 25, 2014 | 06:58 AM
wyoming9's Avatar
Red face
I know what a resistor does even if it is hidden in a heat sink.
My issue is with the Haynes Manual calling it a solenoid resistor when there is no solenoid in the injector circuit.As Toyota calls it the injector resistor.
Good old Mopar Ballast Resistors encased in a ceramic coating that got brittle so very soon.
Old May 25, 2014 | 07:25 AM
millball's Avatar
Each injector has, at its core, a solenoid.
A magnetic coil that lifts the pintle pin.
Old May 26, 2014 | 08:06 AM
wyoming9's Avatar
Red face
So then injectors should then be called fuel solenoids to correspond with the solenoid resistor .
I can deal with that then.
calderp
Nov 16, 2015 02:49 AM
pickle6415
Oct 19, 2015 08:08 AM
toyhaulert100
Sep 24, 2015 07:55 PM
runnermedic
13
Sep 21, 2015 05:20 PM
TransAmBandit
Sep 20, 2015 06:08 PM
