General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Headlights and high beam indicator quit working
Old Mar 11, 2015 | 02:47 AM
Gbaker's Avatar
I recently purchased a 1989 Toyota 4x4 truck. When I purchased it, everything worked fine on it. One evening I went out to drive it to work and the headlights wouldn't come on. All other lights, including the dash lights, tail lights, parking lights, etc. work fine with the exception of the headlights. Also, the high beam indicator on the dash doesn't light up anymore. I checked all the fuses and they are good. I replaced the headlight relay and even replaced the light switch on the steering column, but still no headlights or high beam indicator. Does anyone have any idea where to look next? There seems to be several posts on the internet with individuals having the same problem, but none have the closure as to whether they solved the problem or not. Any advice would be greatly appreciated.
Old Mar 20, 2015 | 12:36 AM
Gbaker's Avatar
Problem solved
I wanted to let you all know that this problem has been solved. I took it to a Toyota wire guy here in Washington who does this on the side and he found the problem. There were corroded wires located in the wiring harness inside the front passenger wheel well adjacent to the battery. The wiring harness travels from the engine compartment and into the wheel well through a hole near the battery. He said that apparently some mud, water, etc had got onto the wires from inside the right front wheel well and had corroded the wires. He replaced the corroded wires and the lights and high beam indicator are now functioning again. I thought this might help some of you who may be having the same issue. It may be a place to look anyway.
Old Mar 20, 2015 | 01:09 AM
roadtrekker's Avatar
My guess is right its a wiring problem. Glad to know that your issue is already fixed.
Old Mar 20, 2015 | 05:26 AM
Terrys87's Avatar
I didnt see this post but glad you told us what the fix was. Thanks!!!
Old Mar 20, 2015 | 09:13 AM
RAD4Runner's Avatar
Thanks for Sharing
Thanks for sharing what you did to fix the problem. It is highly-appreciated. Some people stay quiet after they have fixed their problem and do not care to share the solution.
Often times, electrical problems are caused by corroded connectors and broken/corroded wiring. That's why we stress to inspect thoroughly (using our senses that came free), look at schematic and use the multi-meter first, instead of wildly guessing and replacing parts left and right.
Regards,
RAD
Scotttekoch
23
Nov 1, 2021 12:41 PM
Ichneumon
Sep 27, 2015 04:21 PM
bigblue82
10
Jul 6, 2015 08:27 AM
gog1968
Jun 22, 2015 05:55 AM
LSUMatt1514
Jun 26, 2002 05:03 AM
