General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
No power to anything
Old Dec 26, 2013 | 09:23 PM
PT3's Avatar
PT3
So I got in my truck turned the key on and the stereo came on like normal then went to start it and it didn't and now I have no power what so ever. The headlights won't come on or anything. Tried jumping it and still no power so I know my battery is still good. I checked my fuses as well and I can't figure out what's wrong and this is my dd so I'm looking for fast answers
Old Dec 26, 2013 | 10:10 PM
dropzone's Avatar
Fossilized
Helps if you mention what year, engine, trans etc of the truck you are referring to.
Check your Fusible Links...
Old Dec 27, 2013 | 03:28 AM
wyoming9's Avatar
Red face
Just what leads you to think your battery is still good??
What was the battery voltage when you checked??
When checking your fuses you checked for voltage to the fuse block other wise your fuses have nothing to do with the issue
what was the temperature??
Did you forget to turn something off??
Door switch stayed closed leaving the dome light on??
If your headlights don`t turn on .
One of a few things battery died or poor connections at battery terminals and ground connections .battery cables just worn out
if you happened to have a short occur while the truck was parked that took out all the fusible links it should be pretty easy to see I would think.
delmert
Sep 30, 2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
shisha1999
Sep 20, 2015 11:44 AM
agrout
Aug 13, 2015 06:12 PM
Sidherish
Aug 2, 2015 01:42 PM
