General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
86 pickup sr5 running lights not working
Old Feb 22, 2014 | 08:40 AM
ryan7128's Avatar
my running lights work when the truck is not running but with the truck running they do not work the fuse just keeps popping i replaced the relay and all the bulbs are new i removed the trailer harness and there is no radio in the truck the clip is missing on the radio but the wires are not touching any advice would be helpful
Old Feb 22, 2014 | 01:07 PM
wyoming9's Avatar
Red face
Is there any other circuit not working when the engine is running??
Is it only with the engine running or does the fuse open with the ignition switch on??
Any place any of the light harness might be getting pinched with the engine running??
Some place your either overloading that circuit or have a short to ground .
Anything else wired into the light circuit ??
Light for the radio shorting to ground with the key on?? Could just be two wires rubbing at the back of the plug.
Old Feb 22, 2014 | 01:31 PM
ryan7128's Avatar
The dash lights don't work also but the radio wires aren't touching and I also unplugged the cig lighter cause I know when u turn light on it runs through there also I pulled out the wiring that went to some lights the po had on the truck
Yont283
Sep 23, 2022 08:06 PM
dirtrider0129
10
Jun 24, 2015 12:24 PM
gog1968
Jun 22, 2015 05:55 AM
streetuner15
Jun 18, 2015 10:59 PM
