General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
A possible solution for random starting
Old Aug 5, 2014 | 11:54 PM
chefdave's Avatar
Hi
have been suffering from clicking on starter motor and no starting. headlights on turn key headlights did not dim. so went looking for a break in high amp cables. +ve cable on starter motor need a 3/4 turn to be fully tight. fingers crossed problem is solved. if not starter out and replace contacts.
Old Aug 6, 2014 | 12:13 AM
wyoming9's Avatar
Red face
Just because you found one loose connection does not mean there is not more.
While changing contacts in the solenoid can`t hurt it might not fix your problem
Old Aug 6, 2014 | 12:25 AM
chefdave's Avatar
Hi wyoming
Thanks for input believe fault lies in high tension circuit which is very simple to follow and test. Now it starts on turn of engine with more oomph (?)
Checked both battery connections added another earth lead from battery to engine block. Might upgrade -ve cable from starter to battery. All connections are extremtly clean. Both battery and alternator replaced in last 9 months.
Old Oct 14, 2014 | 09:20 PM
stanz's Avatar
This is a very common and well documented problem. Toyota ran the constant 12v for the starter relay up to the ignition switch and then back through the firewall to the starter relay. Travelling that distance, the voltage can drop enough to prevent the relay from fully switching yet you still have enough juice for your radio, lights, etc.
You can resolve this by re-routing one wire. Another option is to install a universal 'hot shot' starter relay from Summit or Jegs. I went a third option, graft in my own waterproof relay.
Before I learned of this root cause, the PO on my rig had attempted to do their own version of a hot shot relay using a spare fuel injection relay.
All the details of my saga are documented here: https://www.yotatech.com/forums/f116...-relay-276825/
Old Dec 2, 2014 | 11:13 AM
chefdave's Avatar
Have sorted mine for now by cleaning battery terminals and using copper grease for corrsion protection. Now it starts in temps down to -3c with wind chill of -10c. Snow forcast from friday onwards. Will be a good test of adverse cold starting.
Charecter1
Nov 6, 2023 10:08 AM
MO transplant
Apr 23, 2023 11:58 AM
Poncho0206
Jul 10, 2015 06:21 PM
88runnergomas
Jul 9, 2015 01:12 PM
toyoda8488
Jul 5, 2015 10:18 PM
