General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
battery draining
Old Oct 6, 2014 | 08:46 PM
87blyota's Avatar
battery draining
I just installed a new radio head unit and now my battery gets drained while the truck is parked. I rechecked all the connections and didn't have this problem before I installed the radio. Also the truck doesn't "click" like a dead battery. I turn the key and absolutely nothing i turn it a couple times and it'll start or I play with the battery cables and it'll start.
Old Oct 6, 2014 | 10:57 PM
RAD4Runner's Avatar
Search Battery Connection.
Old Oct 7, 2014 | 05:12 AM
87blyota's Avatar
I have a feeling it's my battery connection do terminals or the posts ever go bad
Old Oct 7, 2014 | 07:22 AM
RAD4Runner's Avatar
Yes
Old Oct 7, 2014 | 07:40 AM
87blyota's Avatar
Well I've been playing with it and if I turn the radio off before the truck it won't drain so I guess that is just what I am going to have to do
Old Oct 7, 2014 | 07:55 AM
RAD4Runner's Avatar
Connections are the very first things you should check when you have an electrical problem. Get a battery terminal / connector cleaner. for about $6.
It's not draining your battery, it just keeps power from getting where it should go, AND keeps your alternator from charging the battery while running.
Old Oct 7, 2014 | 02:09 PM
wyoming9's Avatar
Red face
If you had your negative battery terminal disconnected like you should when doing electrical work.
The battery post might be corroded or the terminal is .
Then when you reinstalled the connection was not as good as it should be .
A good cleaning might cure your problem.
Old Oct 7, 2014 | 04:36 PM
87blyota's Avatar
The terminals were pretty bad so I just replaced both. Issue is solved thanks
tazman1972
11
Sep 28, 2015 10:32 PM
toyotasaurus
Sep 24, 2015 03:30 PM
Boomer8404
Sep 17, 2015 07:59 AM
gp66
Sep 14, 2015 12:10 AM
Boomer8404
Sep 10, 2015 09:01 AM
