General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Led dome light problem
Old May 28, 2014 | 05:36 PM
clok's Avatar
So I installed a new led bulb in my dome light in my 89 4runner and it turned on for about 1-2 min. Then it started turning on and off till finally just turned off , so I put the old reg. bulb back in and not working ? , now when I turn the dome light switch on the clock and power mirrors don't work. Or when I turn off the key and turn it back on the clock resets to 1:00 every time , I'm not good with electrical stuff so before I take it to an electrical auto repair ($$) anyone know what could of happened ??
Old May 28, 2014 | 09:46 PM
Discombobulated's Avatar
I would start with checking ALL your fuses, And unless you touched something the wrong way installing the bulb I wouldn't try it again if you do find blown fuses. Might be a defect in the LED but keep it simple start with your fuses and post your results
Old May 28, 2014 | 09:49 PM
clok's Avatar
Ok I will check all the fuses , thanks.
Old May 31, 2014 | 04:07 AM
wyoming9's Avatar
Red face
Have you found your problem and figured out what caused it??
Old May 31, 2014 | 10:59 AM
clok's Avatar
No not yet , gonna check it out tomorrow by starting with checking fuses.
the1998sr5
15
Jul 14, 2020 08:35 PM
rushw
Jul 18, 2015 01:46 PM
msane99
Jul 11, 2015 08:08 PM
Edionne13
Jul 9, 2015 01:59 PM
madxman21
Jul 9, 2015 10:26 AM
