General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
87. Runner high beam problems
Old May 31, 2015 | 10:36 AM
chbarnha's Avatar
I bought an 87 4Runner yesterday and on the way home went to use my high beams. All the lights shut off when I went to use the continuous high beams but the high beams worked fine when I went to use the temporary flash high beams. Any idea of what I need to look at first?
Old May 31, 2015 | 10:46 AM
millball's Avatar
Usually , cleaning the contact points inside the dimmer switch fixes this problem.
It fixed mine.
After you clean the contacts, consider installing a relay controlled headlight harness to minimise the current that the dimmer must pass.
Several different threads concerning the cleaning process and retrofitting harness on here.
Old May 31, 2015 | 12:41 PM
854runnerhunter's Avatar
Hi everyone. My lowbeams do not work and my highbeams only work when I pull back on the switch and will not work if I push it forward to use the continuous high beam mode. Any ideas???
Old Jul 22, 2015 | 05:10 PM
thefishguy77's Avatar
Same as above. Clean the contacts
Scotttekoch
23
Nov 1, 2021 12:41 PM
Cesarl74
Apr 23, 2016 06:07 PM
Ichneumon
Sep 27, 2015 04:21 PM
noahstancik
Jul 10, 2015 11:18 AM
Mr.Black
Jun 21, 2015 10:17 AM
