General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
First gen multiple electrical issues.
Old Feb 6, 2014 | 10:46 PM
warmonger88's Avatar
I have an 83 pickup that has had two days worth of electrical issues. My charge and brake lights came on yesterday after I ran in to a store for about 10 minutes. When I jumped in the truck to leave there was no ignition when I turned the key. Starter didn't turn over, but I had power. I had an issue with the fusible link a few weeks back., so I figured the replacement burnt too. I messed with the wire and the truck turned over, but the lights came on and stayed on. Currently have the charge and brake lights on nonstop. I replaced the alternator and voltage regulator this morning. Lights went off for about 10 minutes. Now they are back. I was coming home from a friends place and list my stereo, then blower, then the wipers slowed down to a crawl. If the truck is shut off it won't start for at least ten minutes, then it starts like nothing is wrong. If I turn on my turn signal, my stereo shuts off, then comes back on. I don't even know where to start. Where is the charge lamp relay on a first gen and how can I test it?
Old Feb 7, 2014 | 01:13 AM
tj884Rdlx's Avatar
test for unopen circuits with a test light between the battery cable and post, confirm all is off when expected. don't forget turn off the interior light if you do this.
then pull fuses for your accessory functions like radio, wipers, to eliminate those circuits and see if the problem persists. could be shorted signal bulb, bad ground, shorted relay stuck closed, grounding out somewhere like that link you mentioned. some stuck relays can be discovered by tapping in the relay box and listening for a sticking switch to pop and finally switch as it should.
if you can't isolate a faulty circuit could be fusebox. this of course is provided the new alt and regulator are confirmed a.o.k. that haps too. new bad part. good luck
Old Feb 7, 2014 | 01:28 AM
wyoming9's Avatar
Red face
Why did you feel the need to replace the alternator and voltage regulator??
While it was out you did have it tested??
You have checked the belt has not loosened up?? As you say it did work for 10 minutes !!
Did you clean all the electrical connections.All fuses check to see if they are open?? Tight in the sockets ??
Battery terminals Bright and tight?? Loose a cell in the battery??
What is the condition of the Wire coming off The Alternator B terminal??
Have you replaced all the ground cables ??
Being the age of this truck all the battery cables should have been replaced long ago.
Do you have a multimeter ?? if not a great time to buy one!!!
Old Feb 7, 2014 | 01:29 AM
JD82Yota86's Avatar
I busted my 80 amp FL about a week ago. My dumb ars was tightening up a loose ground on my alternator with my positive still connected. Which is ok as long as you dont arc your wrench on the exhaust manifold..... Well, I cant find a new FL anywhere. Any suggestions? It is an '86 SR5 FWD w/o turbo.
Old Feb 7, 2014 | 01:33 AM
JD82Yota86's Avatar
I had to solder to fuse back together just to keep rollin......
Old Feb 7, 2014 | 05:55 AM
wyoming9's Avatar
Red face
Which one is it??
I no doubt have one
Just what is a 86 SR5 FWD
Old Feb 7, 2014 | 09:38 PM
Last time I had an issue like this I solved it by replacing both, it was on my old truck though. Also the housing for the voltage regulator was pretty corroded.
No I didn't think to have it tested, just wanted to get it out and replaced.
Jumped in my truck this morning to head to work and the battery was dead. Found my alt belt broke last night. I had another one laying around so I replaced it. It's charging now, but the lights are still on.
Checked all of my fuses and found my cig fuse burned. Everything else was nice and tight, reasonably clean, so I cleaned them anyway.
Bought my battery last summer, keep everything nice and clean, zero corrosion. How do I check to see if I lost a cell?
Wire off the b terminal is old, but well covered, not fluid soaked or split. I cleaned the connections while changing it.
I have not replaced the ground cables yet, I've been dealing with clutch issues until this week.
I've replaced the negative cable, but i haven't been able to find a suitable replacement for the positive.
I do have a multimeter, it's just in my storage, which I can't get to without my truck.
Also, what effect does the charge lamp relay have other than the lights staying on? Does anyone know of a way to bypass or make one?
Old Feb 8, 2014 | 04:31 AM
wyoming9's Avatar
Red face
Ok now this is very interesting two people different issues
One is a 83 Pick up with a no charge issue.
The charge relay is just a relay that when the systems is charging the coil is energized the contacts are in the open position when the coil is no longer energized the contacts close the lights come on.
This is a very simple explanation no need to go into relay logic or explain how it also lights in a over charge condition.
With your battery dead it could have frozen also alternators do not like trying to charge a dead battery .
Battery should be charged with a charger to full charge fore sure with a new alternator .
With a no charge issue your pretty much screwed without a multimeter as you have no idea what is going on.
Just because the B terminal wire looked good what happens is it gets old and brittle from the thermal cycling to the point it no longer conducts.
Bottom line is you need to figure why you have a no charge problem.
Is the alternator charging just not reaching the battery .??
is the light on because of fused contacts or burnt out coil??
Old Feb 8, 2014 | 05:59 AM
I'm putting the battery on a charger after work so I can get a full charge. And I'm going to get my multimeter after work also. I'm also going to go ahead and make a new cable for my b terminal too.
Old Feb 13, 2014 | 07:41 PM
So I've been messing with my electrical system for a few days now and it has gotten better, but still isn't quite okay. I replaced the positive cable, so both are new . Tore apart my dash and found some wiring for an aftermarket air conditioning system. Removed all of it. I just drive 14 miles and stopped to check my mail, jumped back in and no start. Volt meter read 11.20 at the battery, and I waited for about 2 minutes, tried again, and it started. As it ran the voltage on the battery dropped down to about 10.5 before I shut it off again. Now that I've let it sit for 15 minutes with the volt meter attached to the battery and it's back up to 11.57 and starts fine and slowly rising. Any ideas?
Old Feb 13, 2014 | 08:14 PM
How do I check the alternator and what is the amperage in looking for? Same for voltage regulator. Both of these are going to be tested after work tomorrow.
Old Feb 13, 2014 | 11:47 PM
wyoming9's Avatar
Red face
With the engine running you should have @ 12.5 VDC at the lowest point you should have 13 to 13.5 VDC on the high end
This is with the normal electrical loads on.
Headlights Blower motor
Old Feb 15, 2014 | 08:31 AM
So I went by autozone yesterday before work and had them check my battery, them my charging system. My battery is fine, but they sold me a bad alternator and a bad voltage regulator. Once I get the opportunity, I'll swap them out again. Spent two days chasing phantom shorts to find out that autozone screwed up. That's the last time I buy anything from them.
Old Feb 15, 2014 | 12:13 PM
wyoming9's Avatar
Red face
In this day we get poor quality rebuilds from just about every one.
Quality control has fallen by the wayside it seems.
Just remember to charge your battery before your new alternator.
Old Feb 15, 2014 | 01:15 PM
Yup, that's happening tonight.
Old Feb 27, 2014 | 04:16 PM
So after I got two wrong alternators and one bad correct one, as sell as a bad voltage regulator, it is fixed. But on my way to work this morning I lost power for a second. Everything shut off, then came back on, causing a backfire that blew open my muffler. It was when I hit my blinker to turn left, as soon as it came on, power went out. Any ideas? The loss of all electrical was just for a split second. When I left work, it was losing power like that off and on for a few minutes, then drove fine coming home.
Old Feb 27, 2014 | 11:57 PM
wyoming9's Avatar
Red face
Check to make sure all your connections are clean and tight.
Sounds like a loose connection
Old Feb 28, 2014 | 03:53 AM
That's what I thought too, but .y terminals and grounds are new, clean, and tight. I guess I should check the rest of it out too.
Old Mar 1, 2014 | 04:35 AM
So I wasn't able to find anything, but it did cut out yesterday but I didn't have my blinker on. It also did it once this morning while warming up. I wonder if it was coincidence when it cut out the first time as I was changing lanes.
Old Mar 1, 2014 | 10:10 AM
wyoming9's Avatar
Red face
It sure sounds like a loose ground connection.
You have a good one to the inner fender.
A good solid one to the steel part of the engine block.
Someplace something is loose .
I think the blinker thing was just pure chance . luck of the draw.
Another thing did all the alternator changing maybe bump the coil wire??
With those boots on I did that once pulled it out far enough it did pretty much the same thing till it burned off.
That could shut the ignition off but not the rest of the electrical system
